Author Topic: Trainworx N-scale Mini-89 (M89) Coupler Testing  (Read 6422 times)
  • Respect: +656
« on: January 14, 2021, 03:38:50 PM »
The trailer announcement led me to this:
Need more info (pix from the top, etc) but sounds promising!
Mark
  • Respect: +1826
Re: Trainworx N-scale Mini-89 (M89) Coupler Testing
« Reply #1 on: January 14, 2021, 05:36:06 PM »
So the only M89-to-M89 is the one at 1:37?   (And the rest are a demonstration of compatibility I presume.)    Interesting that one hardly has any bounce, compared to the others.
The 1 locos equivalent to 24 cars may be appropriate for straight/level track, but with grades & curves my rule of thumb for a Kato CC diesel was more like half that (assuming all metal wheels and low flanges).  Anything that can slip 10 locos would probably stringline on most layout curves.
Size-wise tho, they don't appear to be much smaller than any of the others.
(Notice too, how the MT did a little slinky as soon as the train started up.)
« Last Edit: January 14, 2021, 05:39:15 PM by ednadolski »
EspeeGoldenState
  • Respect: +124
    • Modern Southern Pacific
« Reply #2 on: January 14, 2021, 06:36:43 PM »
My thoughts too, looked pretty much the same size as all of them. Though, there was no ScaleTrains couplers tested,  but we all kinda know how well those work.
I don't understand for yet another coupler type in the market?
Chris
Attempting to model a modern Southern Pacific based in 2015/2016...
Also, I have a passenger train addiction...
  • Respect: +5556
« Reply #3 on: January 14, 2021, 06:47:34 PM »
Yes, the variety of (oversize) N scale knuckle coupler is surprising (especially since MTL had one for many decades, and it works very well).
Now a smaller, and more prototypical-looking coupler that actually works would be most welcome (even if it was not compatible with the oversize couplers).  I realize that MTL makes a correctly sized coupler, but I wouldn't call it a "working" coupler.
jpwisc
  • Respect: +2516
    • Skally Line Blog
« Reply #4 on: January 14, 2021, 06:48:18 PM »
It looks smaller to me. Even if it’s only a 10% size reduction it’s a step in the right direction. I’m glad to see Pat adding some innovation to the market.
Karl
  • Respect: +656
« Reply #5 on: January 14, 2021, 06:54:27 PM »
Yes, smaller. The video doesn't reveal much but I can tell that they are a bit smaller.
The announcement alluded to this:
   -If you prefer the larger couplers, I still have a stock of the assembled under frames with
          trucks, Fox Valley metal wheels and the larger couplers in black and mineral red.
          Part #4003, $5.95 each (not packaged for retail sale)
muktown128
  • Respect: +119
« Reply #6 on: January 14, 2021, 09:04:12 PM »
Somebody failed math.  6 x 24 does not equal 146  :facepalm:
  • Respect: +1680
« Reply #7 on: January 14, 2021, 09:23:40 PM »
And English, on the spelling of "Special".   ;)
It definitely appears some factor of smaller, for sure.
  • Respect: +1826
« Reply #8 on: January 14, 2021, 09:47:58 PM »
One other point about the strength test.   To me at least the result does not seem all that impressive.   I recall testing the LEZ coupler by using one to vertically lift a 10-ounce weight, and it held up fine.  So I would expect a larger coupler to be able to do substantially more.  You would need to gang up a lot of n-scale locomotives to pull with enough force to induce a failure of the plastic.
  • Respect: +1331
« Reply #9 on: January 14, 2021, 10:15:15 PM »
If they are dirt cheap, I could see myself getting a lot of them to add body mounted couplers to my older cars.
  • Respect: +5556
« Reply #10 on: January 14, 2021, 10:35:43 PM »
MTL Z scale couplers are smaller than regular N scale couplers, and they also couple to the N scale ones.
I liked the Arnold coupler they used in the S-1 switcher, but it was only included with the model. No way to buy large quantity to convert your fleet of cars.  Plus it dint; work well with MTL N scale couplers without a slight modification.
Then there was the DKS' coupler, but that doesn't seem to be a viable option either.
  • Respect: +1826
« Reply #11 on: January 15, 2021, 12:36:02 AM »
It was patented (https://www.freepatentsonline.com/20130256254.pdf)  but never produced.
  • Respect: +5556
« Reply #12 on: January 15, 2021, 12:46:40 AM »
  • Respect: +1527
« Reply #13 on: January 15, 2021, 02:13:12 AM »
Peteski:  I'd love to see MT market versions of their Z coupler designed for N scale.  It wouldn't be hard to put the coupler itself on 1015 and/or 1025 shanks, and they'd be direct replacements for the (probably millions) of N couplers already out there.
Teditor
  • Respect: +28
« Reply #14 on: January 15, 2021, 03:04:19 AM »
With wisker springing like the newer Kadee HO Scale ones.
Teditor
