Author Topic: Three way switch examples  (Read 2423 times)
Coxy
  • Respect: +7
    • Coxy's N Scale and Railroading Blog
« on: April 22, 2013, 12:05:50 AM »
I've seen plenty of three-way switches on model railroads but very few on the Prototype.
I happened across this three-way while using Google maps to look at tracks around Chevron's Yard near the Richmond Parkway in Richmond California. It's the only one I am aware of in the Bay Area.
http://goo.gl/maps/1yzLp
The three-way is actually on the downslope of a very short grade as this yard was once operated as a small hump yard.
If you have other google map references or photos of three-way switches, please post them here. Looking forward to seeing some other examples.
  • Respect: +2512
Re: Three way switch examples
« Reply #1 on: April 22, 2013, 12:26:55 AM »
Here are two sets of double triples (two three-ways) from the eastbound and westbound humps at UP's Bailey Yard in North Platte:
  http://goo.gl/maps/YRaBc
  http://goo.gl/maps/HZzLK
BNSF hump at Barstow, another double:
  http://goo.gl/maps/BrNPO
A single triple, UP/ex-SP West Colton Yard. Hard to see the middle leg from all the retarder dust:
  http://goo.gl/maps/ww7ID
The challenge here is to locate three-ways that are not downhill from a hump (or, in your case, a former hump). Just like trying to find examples of double- or single-slip switches not in a passenger terminal throat.
Coxy
  • Respect: +7
« Reply #2 on: April 22, 2013, 12:31:23 AM »
Yes, exactly. Not sure I have ever seen one not part of a hump yard.
  • Respect: +2512
« Reply #3 on: April 22, 2013, 12:43:40 AM »
D'oh! :facepalm: I was standing on one just a month ago! Hard to see in the shadows, but it's there:
  http://goo.gl/maps/a8yxK
Granted, this is sort of a cheat... it's on the California State RR Museum property, leading into a car barn. Better yet, it's a 3-way stub switch. Construction did look like original SP, so it is possible this was existing before the shops were converted.
  • Respect: +1248
« Reply #4 on: April 22, 2013, 12:45:00 AM »
Another museum.
http://binged.it/15A6ZEl
rswinnerton
  • The Anti-Ed
  • Respect: +20
    • Luxury Rail Travel
« Reply #5 on: April 22, 2013, 01:53:01 PM »
The yard at the Church & Dwight yard I serve has a 3 way switch. They added it when they added the third track. They unload covered hoppers towards the bottom of the picture.
Russ Swinnerton
Dr. of Ferroequinology
www.LuxRailTravel.com
conrail98
« Reply #6 on: April 22, 2013, 01:55:44 PM »
Is that a crossover also right there going into a new switch (or old switch?) at the unloader? If so, this must make the Ed's Law HoF,
Phil
- Phil
  • Respect: +2512
« Reply #7 on: April 22, 2013, 04:38:18 PM »
"Ed's Law" indeed. Two "odd" bits are combined here - a true scissors crossover (or used to be), with one leg a 3-way. Also really unusual is that the 3-way is symmetrical, rather than visibly lapped. I'd love to see a close-up of the points.
Coxy
  • Respect: +7
« Reply #8 on: April 22, 2013, 05:19:32 PM »
Nice example. And good point on the points, I'd like to see a close up on that too. Here's the google map link to the York PA 3-way:
http://goo.gl/maps/YdBEf
It's a funky little yard. Check it out.
rswinnerton
  • The Anti-Ed
  • Respect: +20
« Reply #9 on: April 22, 2013, 06:55:53 PM »
Ill try to get a close up next time I'm there during daylight.
Russ
PS- Ed's Law definitely applies!
Russ Swinnerton
  • Respect: +1515
« Reply #10 on: April 23, 2013, 01:57:36 AM »
Russ:  THAT is what I think of as a 3-way turnout.  The first one posted looked more like a "lapped" turnout to me, where two regular turnouts are overlapped to save space.
For those who want stubs, there is (or at least was) at least one 3-way stub turnout at Orbisonia on the East Broad Top.  Even better, when I was up there in the 80s, the passenger trains used it.
rswinnerton
  • The Anti-Ed
  • Respect: +20
« Reply #11 on: April 23, 2013, 07:22:18 AM »
EBT 3 way stubbie:
Russ Swinnerton
  • Respect: +2512
« Reply #12 on: April 23, 2013, 11:47:27 AM »
I stumbled across this while looking for something else:
  http://goo.gl/maps/Rf0JD
A double-slip in the middle of a Marines supply depot, all by its lonesome.
  • Respect: +7112
« Reply #13 on: April 23, 2013, 12:14:39 PM »
Here's the A&R's three-way stub switch as it appeared in 1992:
http://www.rrpicturearchives.net/showPicture.aspx?id=2319198
  • Respect: +1673
« Reply #14 on: April 23, 2013, 12:30:49 PM »
Sheesh Dave, talk about tight gauging.  When ya gonna built that sucker?
