Is there rail jointer on that joint (to keep the track aligned)? If yes, can't you just solder some electric feeders somewhere else (where the track is more accessible)?
The metal corner angles are attached by screws. Maybe the bottom of those panels is also fastened by screws?
...they're held by screws through every single picket in the picket-fence base.
It wouldn't be "elegant", but could you drill a hole just outside the rail, then file the rail with a knife-edge file until the head and base have a groove down to the web? That would give a bare-metal line from top to bottom, where you could solder the end of the feeder, then cut the top off and file it smooth with the rail head. Very little lump, and no problem getting the paint out of the joint.
